Transmission help
Old Jun 28, 2014 | 09:36 AM
JoeD's Avatar
Awaiting Email Confirmation
Default Transmission help
Ok I have a 2000 Monte Carlo that has a L67 swap done my trans took a L on my way home one night I have the Zzp HD upgrade kit a L67 torque converter already so what year trans can I get an just install it an go about my day with out doing anything to the ecu like would impalas park aves Grand Prixs regals other monte Carlos like what year NA trans will work ??
Old Jun 28, 2014 | 10:28 AM
What transmission did you have in there that blew? Given your other HD upgrade thread, I'm assuming you used your stock '00 transmission.
If that's the case- you would probably have the 3.05 final drive which is used in many of the NA 3800 cars except the 97-03 grand prixs. That would let you use a transmission from an impala, other monte, bonnevilles, buicks, etc.
Old Jun 28, 2014 | 10:51 AM
JoeD's Avatar
I have a stock 00 factory trans so when i go get a other trans what model year etc do I look for
Old Jun 30, 2014 | 08:10 AM
JoeD's Avatar
Bump??
reaper18769
Aug 3, 2010 10:52 AM
K-Mac Attack
15
Jan 21, 2010 11:12 PM
MyIntimidator
Nov 6, 2007 08:44 PM
mm12678
Nov 1, 2007 09:22 PM
Yellow_Monte
Dec 6, 2006 11:02 PM
