transmission fluid change
Old Oct 17, 2009 | 03:46 PM
KINGSS's Avatar
Default transmission fluid change
So I jus changed the fluid in my 03 and I only droped the pan n changed the filter and fluid as recommended by all of you.I did not change the gasket thogh because I heard they are reuseable is that true or shud I have changed it also?
Old Oct 18, 2009 | 02:08 PM
montes my python's Avatar
The OEM gasket is a pretty sturdy piece and if you cleaned it up and torqued the bolts properly it should be fine, I changed mine when I installed the shift kit and filter but I'm a firm believer of never reusing a gasket unless you have no choice, just my habit
Aaron
Old Oct 22, 2009 | 06:56 PM
rockieg00's Avatar
naw you can reuse your gasket only if its the orignail one .Done it with a hand full of different vehicles. As long as it looks good condition, clean it up and u should be fine
zipsayain
16
Oct 22, 2016 09:16 AM
Bob
Jan 16, 2013 08:14 PM
horrible555
May 7, 2012 01:33 PM
dcnaser
Mar 25, 2012 07:40 PM
Darkness98
Mar 8, 2006 08:32 PM
