First transmission fluid change
Old Jan 16, 2013 | 03:29 PM
Bob's Avatar
Bob
Default First transmission fluid change
I will be taking my monte in this monday to a chevy dealership i have been going to for years, they have got to have one of the best service dept. in pittsburgh. My 2006 lt3 monte has 44,900 miles they are doing this a pan drop and filter change. But they will be also doing a little warranty work for a small oil leak or power steering leak. But i think there a little high for the tranny work, $225, Me and my wife are off from work this monday and that"s why i will be dropping the car off and going back home with her. If it was not for getting the warranty work i think i would go some place else for the transmission, but this is easy for me. As i do not drive my car in the snow, monday could be the first.
Old Jan 16, 2013 | 04:13 PM
Most local trans shops will do the same thing for around $75.00.
$225.00 is waaayyyy to much to pay...id just get your warranty work done and skip the trans stuff at the dealer....
Old Jan 16, 2013 | 05:33 PM
Bob's Avatar
Bob
Thanks STUMPMI, i look into that, made two phone calls to aamco and one to cottman they were around $1oo to $110 it should not matter if i go there and let them do it even if the car is still under warranty?
Old Jan 16, 2013 | 06:04 PM
boggie's Avatar
I do not know much about aamco I have heard pros and cons about them.I have a shop do mine all they do is trannies and nothing else that is all they do 85.00 for the oil and filter. shop some more
Old Jan 16, 2013 | 07:53 PM
06Chevy's Avatar
I had mine flushed at the dealer when my power steering was fixed. I only paid just over 200 for the flush and new front brake pads.
Old Jan 16, 2013 | 07:59 PM
even a buck to a buck 10 is way cheaper than 225!
Old Jan 16, 2013 | 08:14 PM
I changed the fluid & filter on my Monte & wife's Impala SS with
Dexron VI Transmission Fluid & a 4T65e Shift kit from ZZP , Both car's done for $ 180 total at home..
zipsayain
16
Oct 22, 2016 09:16 AM
horrible555
May 7, 2012 01:33 PM
dcnaser
Mar 25, 2012 07:40 PM
KINGSS
Oct 22, 2009 06:56 PM
Darkness98
Mar 8, 2006 08:32 PM
