transmission fluid change
So I jus changed the fluid in my 03 and I only droped the pan n changed the filter and fluid as recommended by all of you.I did not change the gasket thogh because I heard they are reuseable is that true or shud I have changed it also?
The OEM gasket is a pretty sturdy piece and if you cleaned it up and torqued the bolts properly it should be fine, I changed mine when I installed the shift kit and filter but I'm a firm believer of never reusing a gasket unless you have no choice, just my habit
Aaron |
naw you can reuse your gasket only if its the orignail one .Done it with a hand full of different vehicles. As long as it looks good condition, clean it up and u should be fine
