Switching to 2 Bar MAP
Old Jun 15, 2020 | 09:26 PM
WolvenScout's Avatar
I just downloaded two files from the HPTuners repository. They're both supercharged Montes, an 04, and an 05. But in both of them, the VE table only goes up to 140 kpa, which is the same as my NA Monte. I know the files are from supercharged cars, cause the injector flow rate is scaled by manifold vacuum, whereas an NA is static. I thought the supercharged cars had 2bar MAP sensors, so shouldn't the VE table be scaled differently?
Old Jun 16, 2020 | 08:12 AM
I'm pretty sure they have a multiplier in them that HPTuners can't access. I think TinyTuner + DHP was able to make some modifications to that, but they require BIN files and HPT isn't compatible with that stuff anymore.
Old Jun 16, 2020 | 02:37 PM
That's weird though that it would be setup that way from GM. You'd think the sensor that is responsible for measuring pressure would have a table properly scaled to measure said pressure instead of just going to 140 kpa, and having a multiplier applied.
Would it still work if I took one of those supercharged files and did a write entire to the ECM?
Old Jun 16, 2020 | 02:48 PM
I wouldn't necessarily say it was "set up that way by GM", this is just how HPTuners was able to read the computers. I believe other hex editors were able to make the multiplier changes.
You need to do an OS swap which was what I was saying earlier in the thread.
But hey, if you can figure out a simple way to do it, let me know. From what I gathered it's not possible without a new PCM and OS swap.
Old Sep 7, 2020 | 10:29 PM
I stopped by a junkyard today looking for an ECU from a SC car but ran into a little issue. The only SC car there was a Pontiac GP which had this style of ECU:
My Monte has this style:
Do the 04-05 SC Monte's have the second style ECU that would be a direct swap?
ziggo_2
Feb 7, 2021 03:34 AM
Drkoob
Mar 25, 2016 02:01 AM
robertkevener
Jul 26, 2015 08:35 PM
MJClemm
Jul 26, 2013 05:47 PM
owens91
Jul 1, 2013 07:59 AM
