Switching to 2 Bar MAP
I wanted to know how to change from the stock one bar to a two bar MAP sensor in HP tuners. If it helps, I have a P04 ECM. Do I have to get a file, or a whole ECM from a supercharged monte, and transfer my existing tuning changes to it in order to be able to use a 2 bar MAP?
Originally Posted by WolvenScout
(Post 722278)
MAP Sensor Linear: 94.43 MAP Sensor Offset: 10.34 GM 2 bar map sensor Linear and offsets for HPtuners software MAP Sensor Linear: 207.66 MAP Sensor Offset: 9 GM 2.5 bar map sensor Linear and offsets for HPtuners software MAP Sensor Linear: 244.68 kPa MAP Sensor Offset: 10.21 kPa GM 3 bar map sensor Linear and offsets for HPtuners software MAP Sensor Linear: 329.41 MAP Sensor Offset: -6.35 GM 3.3 bar map sensor Linear and offsets for HPtuners software MAP Sensor Linear: 333.33 MAP Sensor Offset: 33.33 Linked information from a website showing some map info |
Originally Posted by Steelbizkit
(Post 722288)
GM 1 bar map sensor Linear and offsets for HPtuners software
https://www.hptuners.com/help/vcm_editor_parameters_gm_os.htm
only info I can find on it with a screenshot, but I can't look as my laptop is down to find it. |
(Post 722295)
only info I can find on it with a screenshot, but I can't look as my laptop is down to find it. https://cimg4.ibsrv.net/gimg/monteca...597f4cb023.png |
You aren't missing anything. The only way you can go about adding the 2-bar MAP is by installing a supercharged OS onto your car.
MAF tuning and a wideband for 1-bar if you don't want to do the OS switch. |
(Post 722305)
(Post 722307)
That's what I suspected. I only plan on running 5-8 psi of boost, would I be able to run that with just the stock MAF and a wideband?
Don't think you can since a 1 bar will only measure 14.5 psi at wot. Which is atmospheric pressure. Once you build boost it will be 14.5+4 or 5 psi which means map will be maxed.
(Post 722326)
