Supercharge swap
I have a 2000 Monte Carlo SS that has a 3800 none supercharged. I wanna install a 3800 supercharger. Has anyone ever made this swap ? I plan on buying a engine and trans. Do I have to change the wire harness ?
to answer the 2 questions in your post, yes and no.
what i would do (and did) is if the engine and transmission in the car is fine right now, then do a top swap. search the term "top swap" on any monte carlo or grand prix forum and you will find what you are looking for.
I second vikesfan. There is tons of threads on this here and other 3800 forums. Do a little search and you will be reading for hours and hours about what is needed and how to do the swap.
FYI - I moved this thread to a more appropriate section.
Here's a couple of threads in our FWD Tech guides that may be of value on this subject (I'm sure we have more, this is what I found rather quickly):
https://montecarloforum.com/forum/fw...n-3800s-10942/
https://montecarloforum.com/forum/fw...67-swap-14610/
ltrain925
Nov 9, 2007 03:26 PM
earthquake
May 1, 2005 12:56 PM
