starting question!
Old Dec 5, 2009 | 10:21 PM
96_Monte_carlo_LS's Avatar
Default starting question!
hopefully someone can help me i got a 96 and when i start the car it starts and sounds like it wants to bogg out and die, i was wondering if this is a problem and if someone might know what the problem is maybe this has happend to you?
Old Dec 5, 2009 | 11:00 PM
skylark65's Avatar
does the idle RPM's drop? or do the rpm's fluctuate? it could be a clogged fuel filter, car needs a tune up.... quite a bit of small stupied things. is it throwing a check engine or service engine code?
Old Dec 5, 2009 | 11:09 PM
they fluctuate, nothing drastic jus a cuple hundred, i did a tune up when i got the car about 3 or 4 months ago, ngk plugs and wires, no check engine light
Old Dec 5, 2009 | 11:28 PM
Wilco's Avatar
If the problem started after the tune up, you may want to make sure the wires are correctly plugged in, avoid crossfire of the wires by using the guides and may want to check for the wire's resistance as well. Check your EGR, remove it and clean it (if necessary), and don't forget the EGR passage in the manifold, and most def clean the TB/maf. My previous car was a 97 ls and was giving me problems with the idle as well. It turned out to be the EGR and it's passage onto the manifold. The EGR was bad and the passage was almost plugged shut. Also had problems with crossfire which the guides solved.
Old Dec 5, 2009 | 11:34 PM
k thanks ill try that, thanks alot!
Old Dec 6, 2009 | 01:10 AM
gothkid's Avatar
hey im goin thew the same thing. Can u guys recommend me a good brand? I would like to replace it with a performace one. Im the guy that when it breaks i replace it with something better.
Old Dec 6, 2009 | 02:05 AM
Wilco's Avatar
If you're talking about the EGR I replaced mine with a stock replacement and it worked just fine. I'm not aware of a better replacement, but it doesn't mean there isn't one out there. Maybe another member knows something I don't. Just make sure to inspect and check the EGR valve to make sure it isn't sticking and clean the EGR passage into the manifold. It took me a while to get it clean right 'cause there was gunk in there for days.
Old Dec 6, 2009 | 12:07 PM
gothkid's Avatar
I dont belive its a egr valve, but a cloged fuel filter would explain it. I havent changed it for many years i owned it lol. So i just may do that
Old Dec 6, 2009 | 02:14 PM
i believe thats the problem, and im pretty sure they don't make a performance fuel filter atleast ive never heard of one
Old Dec 6, 2009 | 05:53 PM
gothkid's Avatar
Aeromotive ist a performance fuel system company. But i just may get a ac delco or something.
01pacecaredition
Jan 5, 2007 02:36 PM
jogasz28
Jan 1, 2007 02:18 PM
lcmontecarlo
Sep 21, 2006 03:43 PM
01whitess
Sep 20, 2006 10:33 AM
