Spider Gears
Old Oct 29, 2018 | 07:23 AM
Deshun Deathbefore Dishonor's Avatar
Default Spider Gears
This is the output housing
Can someone please tell me what these is I was told spider Gears I don't know tho. I don't know how I did it but my output housing on my transmission had busted and my mechanic said I was missing a gear. I'm looking for friend to let me know exactly what's going on and if I should have to buy another gear
Old Oct 29, 2018 | 12:28 PM
Can someone please tell me if I'm missing a gear that goes into my transmission I have pic . My output housing had a big hole in it and we went to fix the piece that when my mechanic said that I was missing a gear looking for a friend .pls help me
Last edited by Deshun Deathbefore Dishonor; Oct 29, 2018 at 12:32 PM. Reason: Pictures
Old Oct 29, 2018 | 12:37 PM
Default Transmission problem
Busted wide open
Old Oct 29, 2018 | 03:10 PM
Jeffs02rwdSS's Avatar
Unless you broke that with a floor jack or something similar you should save yourself some time and money by looking for another transmission.
Old Oct 29, 2018 | 05:00 PM
I'd suggest you just create one thread in the future. Starting 3 separate threads won't get you any better of an answer.
In terms of the gears/shaft, those are pieces of the differential. There's not nearly enough info to understand what happened. I've seen similar failures before but they were typically because a person did a big 1 wheel burnout that toasted the diff. To get any real info, you need to have a qualified person pull the trans and open it up to see what's broken.
Even if you found all of the pieces, something went seriously wrong to break the diff cover and barf diff pieces out. Its pretty unlikely that absolutely nothing else was damaged from this event. Regardless, you're going to need to clean all of the pieces out of the trans anyways.
WildWestSS
Aug 5, 2011 06:49 PM
Mar 8, 2011 03:12 PM
GYROBLEU
Jul 19, 2010 10:00 AM
captaindamnit
23
Oct 18, 2009 01:03 AM
bwill314
Aug 21, 2008 07:56 AM
