Spark Plug change
Anyone have any suggestions on how to get these friggin wires off... 9 years and 80k worth of heat and cold weather has them glued not only inside the metal sheath but also to the plug.. I ripped all the skin off my knuckles and tore the tops off of the front 3 plug boots trying to get em changed. Its basically down to tearing them apart in small chunks with needle nose pliers to get them off.. I've tried twisting them to loosen them, I've tried everything I can think of.. i gave up after the front three. I'm dreading doing the rear 3 on the 3800.. *sigh*
Ya needle nose would be about the only way maybe some PBD blaster spray.
I've used vice gripes once before to grab the part of the plug boot hanging out of the metal heat shield and twist and pull it off. The metal heat shields add a challenge sometimes.
Doing my tune up fairly soon here. Planning on going with NGK Iridium IX plugs and ZZPs 10mm LSx wires. I've used that same combination on my supercharged 04 and had not a single problem.
I've heard the rear plugs are a pain to get to but I've got a thexton tool to help rock the engine forward. Hopefully it all works out. Do you guys grease up the plugs or leave em dry?
A little anti-seize on the threads and then I drop a dab of die electric grease in the plug boot (helps insulate from weather conditions, among a few benefits).
Years ago I read the "trick" on accessing the rear plugs on my 3800. It may have been here at this MB, or it may have been another one.
Like someone has already said, remove the dogbones on the front. Now you stand behind the open drivers door with your right foot resting on the parking brake. Tranny in park. Start rocking the car forward, then back. You will notice the engine rocking forward, then back. OK, you have to time this, when the motor rocks forward, stamp on the parking brake. Wa-La! You can get to the rear plugs!
What I did was, disconnect the downpipe from the resonator, remove the dogbone on the driver's side, just remove the bolt to the engine bracket on the passenger side and flip it up, put the car in neutral, and you can roll the engine forward by hand. Now you can replace the front 3. Now, on the left side(passenger side) dogbone, there is another hole in the bracket you can use, roll the engine forward by hand and just re-insert the bolt and it will hold the engine in place.
I used AC Delco Iridiums as they were the stock plugs I removed, and a set of Taylor Street Fighter wires. Nice set with lower resistance than stock and heavier silicone jackets and boots.
I also suggest replacing your upstream O2 sensor while you are there. On a high mileage car it will help, and since you have the engine forward it's much easier to get to.
I have yet to require the "roll the engine forward" trick. But I have dealt with the tough to pop the wires off problem.
The issues I have had were related to the tin heat shields, they prevent you from getting a good grip on the boot itself. My answer was to grab a pair of vice grips, use those to grab what little of the plug boot was sticking out past that tin heat shield, a good grip with the vice grips and I could wist the boot all the way around to break it free and pull it off.
Yea, the heat shields are a pain. I used a pair of channel locks and twisted the boots to break them loose.
And didn't smash any of the shields either!
6th Gen ('00-'05): Spark plug change
aintnunbutapenut
Nov 26, 2015 08:48 PM
Cowboy6622
Feb 6, 2012 10:56 AM
BeachBumMike
Aug 15, 2007 07:06 PM
