2001 Monte Carlo SS spark plug change
Old Oct 17, 2010 | 12:58 PM
churritos626's Avatar
Default 2001 Monte Carlo SS spark plug change
im trying to figure out a way to get to the spark plugs on the rear bank of the engine but im not sure what to do. the front was the easiest but the back it quite a challenge. has anyone gotten around this bnefore? any suggestions will help us greatly
thanks
Old Oct 17, 2010 | 01:44 PM
read this topic, it should help with changing out the back plugs , good luck...............Tune up
Old Oct 18, 2010 | 01:38 PM
zipper's Avatar
It's not hard to do at all. Break it loose with the socket first, the put a spark plug socket onto the spark plug and continue unscrewing until it comes out. That way the spark plug won't fall out. Just reverse procedure to put the new ones in. I never move the engine, there's enough room back there. It should take 15-20 minutes to do the job.
Old Oct 18, 2010 | 05:53 PM
labnjab's Avatar
There's plenty of room on the 3.8 liter to do the plugs without rocking the engine forward. Shouldn't take more then 15-20 minutes to do all 6. Just make sure the engine is cold or you will burn yourself
jlanes02monte
Apr 15, 2018 12:24 AM
aintnunbutapenut
Nov 26, 2015 08:48 PM
werewolf-odst
38
Nov 24, 2015 11:17 AM
80joe
Mar 2, 2011 08:20 PM
BeachBumMike
Aug 15, 2007 07:06 PM
