Smoking
Old May 14, 2010 | 03:41 AM
brettmonte's Avatar
Default Smoking
My 87 monte has one flaw, when i start it cold, it gives a slight puff of oil smoke..then goes away..not using any oil...whatta ya think guys??car has 86k for milage..car was well maintained every record was kept...Engine is 305 4bbl stock w/headers i installed..valve seals maybe???
Old May 14, 2010 | 01:39 PM
nitehawkjcb's Avatar
Either the valve seals or piston rings.
Old May 15, 2010 | 04:36 AM
brettmonte's Avatar
Last year i bought some HO heads but havnt done anything w/them..Maybe ill have then done over and install...Performance wise i dont think ill seea lot, but may eliminate the smoking problem...
Old May 15, 2010 | 06:39 AM
mrl390's Avatar
If it only smokes briefly on startup, I second valve seals. If it were the rings it would smoke constantly and get worse the harder you run it.
Old May 15, 2010 | 06:47 AM
monte07's Avatar
it is the valve guid seals like mrl390 said i would replace them. on the bright side if you take the heads off if any you can get the heads ported and polished while there off and be able to get the coper colered guides they have a better life span.
bdrastic214
Apr 7, 2015 07:13 PM
GO!Auto
Feb 25, 2013 06:12 AM
Budsjlm
Jul 14, 2011 09:43 PM
blackmonte781
Apr 24, 2011 10:22 PM
BeachBumMike
Dec 19, 2006 07:06 AM
