Running hot
Old 06-04-2012, 06:06 AM
The pattern I posted and the torque spec are straight from the GM shop book.
I hope all comes together correctly. Sounds like you're getting there though.
  #32
Old 06-04-2012, 10:40 AM
Why are you posting this in this thread?
That is NOT an oil temperature gauge, it's an oil PRESSURE gauge.
And it sounds like it is functioning 100%
Good Call CHIBI !!!!!
Unbelieveable
  #33
Old 06-09-2012, 07:10 PM
sisk's Avatar
Ok we got her put all back together. Everything seems to be good, except she is ideling real high. She was occasionally doing this prior to this problem but now it's all the time. Not sure if we missed something.....Do you have any ideas?
This took us much longer then expected and a bunch of aggravation later we feel good about it. We appreciate all your help!!!
  #34
Old 06-10-2012, 12:57 AM
Just so it's seen, my suggestion in your new thread is check for vacuum leaks. Using a can of starting fluid and mist it around all vac connections and seals, listen for a change in idle.
  #35
Old 06-11-2012, 06:12 PM
sisk's Avatar
AMEN!!! Had one of the spark plug wires wrong, she is purring like a kitten!!!
Thanks Maniac for all your wisdom you helped us to make a LARGE job easier...
Thank you so much.
  #36
Old 06-11-2012, 10:39 PM
Awesome! Glad to hear it was something simple!
  #37
Old 06-12-2012, 05:52 PM
sisk's Avatar
Sorry, have one more question. Seem to have just a slight miss causing my check engine light to flash, onstar says its a misfire. Checked the spark plugs again everything seems to be good. Any ideas?
  #38
Old 06-12-2012, 09:01 PM
Are you using Bosch plugs instead of AC Delco?
  #39
Old 06-13-2012, 03:15 AM
sisk's Avatar
yes, that is what was originally in the car. just had them changed for the first time before all this happened. they said the wires were still good. i know the wires are and pretty sure the spark plug are too.
  #40
Old 06-13-2012, 08:10 AM
Bosch are known to not work great with W-Body cars.
Your problem could just be those plugs...
Quick Reply: Running hot
