rough idle
Old Jun 28, 2013 | 08:28 PM
Video's Avatar
Default rough idle
I have a 2000 monte carlo ss with the 3.8. It idles rough and bogs down and shudders when i initially take off from a dead stop. Once it gets going its fine. Ive started taking apart the throttle body to clean it. I cleaned the MAF sensor and im getting a new IAC valve. Is there anything else i should check out before i put everything back together?
Old Jun 28, 2013 | 11:46 PM
- if it has the factory cat, that is probably bad. GM had a large batch of bad cats in '00 and '01 (they extended the warranty on the cats, but that is now expired).
- Change plugs and wires (do not use BOSCH plugs, stick with AC Delco or NGK).
schmicr
Nov 21, 2014 12:43 PM
Brinksta
Jul 16, 2008 06:49 PM
lovemymonte77
Jun 4, 2008 11:20 PM
bigcoop_03ls
Mar 6, 2007 06:40 PM
mtmer1
Oct 24, 2006 09:54 PM
