6th Gen ('00-'05): lower mount.
Old Jun 23, 2013 | 07:35 PM
Dstevens's Avatar
Default lower mount.
When I start my car I can feel and here the engine jump a little bit. I think It just needs to be tightened down but I may have to replace it. I tried getting at it from the top but there is to much stuff in the way like the silver box for the brake booster. Is there an easy way? or do I just have to take everything off. The a/c hoses are in the way to. Or maybe if I jack the car up and can go to the bottom. Just looking for a little advice before I jump in.
Old Jun 23, 2013 | 09:19 PM
turbo monte's Avatar
you can get to it from the wheel well if you remove the wheel, you will have to support the engine and trans from under the car so when you take the mount off the engine and trans donw fall onto the ground.
Old Jun 24, 2013 | 04:27 AM
Dstevens's Avatar
Ok. thank you. Going to be working on that tuesday.
Old Jun 25, 2013 | 12:53 AM
Dstevens's Avatar
Need the whole thing replaced. dag nabit.
Old Jun 28, 2013 | 07:30 AM
VictoryRedSled's Avatar
does it look as bad as mine??? hahah
Old Jun 29, 2013 | 11:29 AM
Dstevens's Avatar
Ill let you know tonight. lol.
machine2950
Jun 28, 2010 09:59 PM
GooberMT
24
Sep 26, 2007 09:06 PM
rrobert05
Jul 5, 2006 12:03 AM
victoryred05
Feb 3, 2006 06:12 AM
01blackmonte
Jan 4, 2006 12:01 PM
