Random LOUD supercharger whine??
Old Sep 26, 2011 | 04:17 PM
Mr.Monte's Avatar
Default Random LOUD supercharger whine??
so i just got home from cruisin around a little bit and its been raining all day. while i was out i thought id just turn the traction control off and spin the tires real quick. (thats always fun). then i was making a turn and then i did it again. (this is was in an empty parking lot no worries.. lol) but then the Supercharger i guess woke up and was making this really loud Whine. it would do this only when i would accelerate.. dont get me wrong it sounded completely awesome. but i thought it worried me a little so i stopped. so i turned the traction control back on and started to drive home and which it gradually went away..
can someone explain what happened?
Old Sep 26, 2011 | 04:30 PM
nitehawkjcb's Avatar
Check for any leaks, check your intake tube - putting an aftermarket intake on a supercharged car really makes the blower louder, perhaps you have a leak somewhere?
Old Sep 26, 2011 | 04:42 PM
Mr.Monte's Avatar
i have a stock intake and everything, it sounded as if i had an aftermarket intake or somethinggg. and i checked for leaks and everything looks perfectly fine. thanks!
Old Sep 26, 2011 | 05:17 PM
mrl390's Avatar
What controls/regulates the boost on the L67? Maybe something is wrong and letting it build too much boost?
Old Sep 26, 2011 | 06:07 PM
The BBV "controls" boost, but it only limits boost, so if that was failing the whine would be quieter
Perhaps it was colder outside than normal, colder weather = more boost
Old Sep 26, 2011 | 07:52 PM
My guess would have been the intake came loose too.
Old Sep 26, 2011 | 10:09 PM
Mr.Monte's Avatar
hmm thanks for all your help guys. im going to check the intake again tomorrow
EDIT: Oh! and i forgot to mention it was still making some kind of squeek in the steering wheel while this was happening. once it went away the squeek went away. idk how these two can be related in the slightest bit but who knows. ill just take it easy for awhile on it.
Old Sep 28, 2011 | 09:55 AM
03SS/00GSE/93LX's Avatar
when i was making a turn and then i did it again.
It wasn't your supercharger making noise, it was your power steering pump. This is a common L67 thing- when turning hard, the pump temporarily starves and gets LOUD. It gradually goes away.
If you think you're going to make a habit of doing donuts or flying around parking lots like that, go ahead and flush/fill your power steering pump and make sure it's filled to the right capacity. It should reduce this from occurring as much.
Old Sep 28, 2011 | 12:36 PM
Mr.Monte's Avatar
AH! genius. thank you! it had to be that im almost positive. because i remember another time i made a quick turn in a culdesac and it made the whine/squeek. thanks alot!!!
Old Sep 28, 2011 | 12:50 PM
space monkey's Avatar
its your power steering pump check for cracked resevoir or broken hose this happened alot to me with my camaro.
nascar43
Mar 31, 2011 04:52 PM
RickAKATed10
32
Feb 17, 2010 09:38 AM
cain45
Aug 20, 2007 08:57 AM
SoCalSS
Aug 18, 2005 12:45 PM
SoCalSS
Aug 13, 2005 04:51 PM
