Problem with 1984 Monte
Old Nov 3, 2010 | 10:03 PM
crims0ngh0st's Avatar
Default Problem with 1984 Monte
1984 Monte, 4.3L. Fuel pump has no power. If I put gas into throttle body, it starts, for a second, until that gas runs out. I took off the fuel pump, put in a new one. Checked the plug, plug had no power. So I want to check the relay but I don't know where it's at, and can't find any info about it anywhere. Please help.
Thanks
Old Nov 20, 2010 | 10:02 AM
88ss408's Avatar
it should be on the fire wall somewhere ? they also have a fuse you will want to check that as well .
Old Nov 20, 2010 | 06:11 PM
monte07's Avatar
it should be in the relay box under the hood if it is there also it could be in the fuse box in the cabin of the car
Old Nov 21, 2010 | 01:18 AM
Budsjlm's Avatar
no relay box in a 4th gen, check your fuses it's under the dash on the driverside right by the e brake, and your wiring under the hood, somthing could have corroded
Veritas
Feb 23, 2008 08:23 AM
Fiky206
Sep 28, 2007 08:33 AM
Sydwayz
Mar 22, 2007 10:14 PM
Double Deuces
Jul 19, 2006 05:43 PM
Jofonce
Aug 9, 2005 03:10 PM
