Problem with 1984 Monte
1984 Monte, 4.3L. Fuel pump has no power. If I put gas into throttle body, it starts, for a second, until that gas runs out. I took off the fuel pump, put in a new one. Checked the plug, plug had no power. So I want to check the relay but I don't know where it's at, and can't find any info about it anywhere. Please help.
Thanks |
it should be on the fire wall somewhere ? they also have a fuse you will want to check that as well .
it should be in the relay box under the hood if it is there also it could be in the fuse box in the cabin of the car
Originally Posted by monte07
(Post 276243)
