PLEASE HELP!! 1987 monte LS wont start all of a sudden!!!
Sorry 2 read that you have not been able to resolve your problem.
Please check back on your thread later, and hopefully one of our expert tech member's will read your thread & be able to assist.
If it's getting fuel & spark it should fire ? ? (A short or clog in fuel line ) Is the fuel pump OK ?
We wish your Good Luck 4-Sure.
thanks kid space....i appreciate you and sparky with the attempts.....it took me a few days but it all boiled down to hopefully a bad distributor shaft. didnt really notice it at first but its all rusted out and the coating on the coils are corroded off. (i think thats spelled right) its not sending the correct firing order. i checked all the spark plugs and some where getting a great spark....one or two where weak and one wasnt getting a spark at all. so today im going to put a new distributor shaft and rotor on along with the control modulator and coil pack i already replaced. hopefully this should do the trick! again thanks to both of you!!!! even the chevy experts online couldnt tackle this one!!! (justanswer.com) <<<<<<crap
You are Welcomed 4-Sure...I hope that you have found the problem & that your Monte is back on the road soon. It's difficult many times to help a member by just their posted words, but we try our best...
Please let us know how things work out `OK
Good Luck
Good Luck
Does this engine use a timing belt or chain? I had a belt go out on me with a different car and I was stumped until I took the timing belt cover off. That is where I would look if I were you. Good luck!
schoentges16
02-27-2021 06:43 AM
slobamess
09-04-2009 10:38 PM
ChevRev34
02-24-2008 01:10 PM
