1987 monte wont start need help
Old Feb 14, 2008 | 10:09 AM
solojazz's Avatar
Default 1987 monte wont start need help
hello everyone, i just came about a 1987 monte ss and it wont start. i replaced the battery and the lights come on but when i turn the key to start nothing happens i dont even hear a click. oh and i had to replace the ignition switch. can anyone help?
Old Feb 14, 2008 | 12:03 PM
kweef's Avatar
Default RE: 1987 monte wont start need help
y did u have to replace the ignition switch? did that go out and then after replacing it did the car start again? little history on that please
Old Feb 14, 2008 | 03:52 PM
88ss408's Avatar
check your battery cables if you have a good battery and good cables maybe it the starter take a screw driver and jump the solonoid to see if it will start if it does not then i am pretty sure it the starter
Old Feb 14, 2008 | 05:55 PM
GrandPaDave's Avatar
Worst case scenario would be that the engine was seized.
Old Feb 14, 2008 | 06:03 PM
RickCoMatic's Avatar
Put a wrench on the Big Nut holding on the Harmonic balancer and see if the Engine WILL turn over.
Attach a set of Remote Starter Cables right on the Starter Solenoid and send 12 Volts directly to the Starter and see if the Starter will spin.
An alternative method is to use a metal tool and short across the Posts ... or, Stripped ignition wire. See if it's the Starter Motor.
Might very well be if that starter is 20 years old!
Old Feb 14, 2008 | 08:46 PM
Bxbootlegger's Avatar
Some of those cars have 2 fusable links. I would check that out as well. Also pull the small wire off the starter and with a test light attached try and start the car.
Old Mar 12, 2008 | 12:08 PM
rj's Avatar
rj
If the car came with an alarm, that could be what's preventing it from starting. Ask me how I know.
My '86 has an alarm on it. It will disable the starter whenever it feels like it. And since the PO lost the key FOB to disable the alarm....................
I have no way to disable it if it ever decides to go off.
Old Mar 12, 2008 | 04:29 PM
86Ls's Avatar
ORIGINAL: RickCoMatic
I'm not sure he will be able to just turn it over. When we put a new chain drive in my car we couldn't get the motor to turn over without taking the plugs out. We ended up getting about 5 foot peice of pipe, take all the plugs out and THEN barely got it to turn...
schoentges16
Feb 27, 2021 06:43 AM
bigdomvegas
Oct 21, 2017 07:54 PM
BrandonStebing
Jul 25, 2014 11:03 AM
Knightwolf702
May 14, 2014 07:13 PM
nazztn8
17
Apr 7, 2011 03:47 PM
