pcm issues
Old 02-06-2011, 02:26 PM
If I am not mistaken, it's typically some (not all, and I don't recall which ones off the top of my head) of the aftermarket radio harnesses that interfere with flashing the PCM
BBEngineer
  #32
Old 02-06-2011, 08:41 PM
Wonderful! I am going to have to try this. We had been taking the PCM out of the car and flashing it with an offboard and reinstalling it. I might do the radio fuse just to be sure. We are using a PT so should be the same.
  #33
Old 02-26-2011, 11:26 PM
Im going to hijack
Im having a very similar issue with a 01ls monte with the 04 N/A 3.8 harness and ecu. I keep getting the 02 codes same as above and I check the plug and there is no voltage. The problem with this is that it misfires unless I set it with the programmer to run in open loop. How can you fix this?
  #34
Old 09-19-2012, 08:53 AM
sorry to bump such an old thread , my 04 mc ss sc has been having the p0134 and p0135 for a while , so i replaced the wire from the rear of the engine to the sensor with a new one and replaced the 02 with a new denso , same thing codes pop up . Now someone on another site , i don't even know if it was a gm car said check the 02 sensor fuses . Do we have 02 sensor fuses ?
I gotta get this inspected by the end of the month and don't know what to do .
mods 3.6
open cone
180 stat
ssac headers
zzp mail order tune
aeroforce to monitor things.
  #35
Old 09-19-2012, 08:58 AM
Are you 100% sure the replacement sensor is heated?
The_Maniac
11-10-2010 09:42 AM
dickie34
07-29-2006 01:02 PM
Screamin SS
09-09-2005 12:45 PM
scortch
07-11-2005 04:10 AM
montejass
04-28-2005 01:29 PM
Quick Reply: pcm issues
