P0201 code
Old Aug 26, 2014 | 04:45 PM
vikesfan's Avatar
rtv works well.
Old Aug 26, 2014 | 06:59 PM
JoeD's Avatar
Awaiting Email Confirmation
Which rtv??
Old Aug 27, 2014 | 08:26 AM
03SSLE's Avatar
If swapping injectors didn't solve the problem you need to check the wiring to insure you have a complete circuit and the correct voltage signal to the PCM.
Permatex High Temp Gasket maker should cure the exhaust leak unless you have major warpage at the flange(s).
Old Aug 27, 2014 | 09:46 AM
JoeD's Avatar
So would the silver tube of rtv gasket maker work?
Old Aug 27, 2014 | 09:48 AM
JoeD's Avatar
Originally Posted by JoeD
So would the silver tube of rtv gasket maker work? An I have power I check them all with a nord light I think it's just the exhaust leak making it shake real bad cause I'm not getting any codes at all
Old Aug 28, 2014 | 08:41 AM
03SSLE's Avatar
You want to use the Ultra Copper Gasket Maker
phatboy313
Apr 15, 2013 07:12 AM
yfz450man
Jul 24, 2011 02:21 AM
cj702
Aug 28, 2005 12:50 PM
chorales
Jul 24, 2005 05:33 PM
king2805
Jul 14, 2005 10:34 AM
