P0201 code
Old Aug 25, 2014 | 08:56 AM
JoeD's Avatar
Awaiting Email Confirmation
Default P0201 code
Can anybody tell me how to get rid of this code car shakes really bad while trying to drive 2000 l67 swap Monte Carlo 42.5 injectors
Old Aug 25, 2014 | 09:01 AM
Hi `Joe, sorry to read about your problem...
Check back to see what our expert tech member's post on your problem...
Until then, check out the below links > Good Luck <
Part 1 -How to Test the Fuel Injectors (GM 3.8L)
troubleshootmyvehicle.com › GM3.8L
Feb 11, 2011 - Diagnosing Trouble Codes: P0300, P301, P0302, P0303, P0304, P0305, P0306. How to ... A BAD fuel injector can cause your 3.8L Buick (or Chevrolet, or Pontiac, ... P0201: Injector #1 Control Circuit. .... 1993, 1994, 1995, 1996, 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004, 2005 ... Monte Carlo 3.8L.
P0201-p0202-p0203 -p0204 -p0205 -p0206 - GM Forum - Buick ...
www.gmforum.com › ... › Tech InfoOBD-II Trouble Shooting
P0201-P0202 -P0203 -P0204 -P0205 -P0206 Description P0201 Cylinder 1 Injector Circuit ... Symptoms The symptoms for this code will likely be a misfire and a rough running engine. ... 1997,1998,2000,2005 year confused Bonneville SSExi.
2001 Chevy Monte Carlo ss: 65K..the check engine light ...
www.justanswer.com › Chevy
Question - 2001 Chevy Monte Carlo ss: 65K..the check engine light came..auto zone - BN. ... It was a gas cap code, so I replaced the gas cap with a new locking one. ....P0200 Injector Circuit Malfunction; P0201 Injector Circuit Malfunction ...
Old Aug 25, 2014 | 09:10 AM
03SSLE's Avatar
You have a loose/dirty connection at the injector, an open in the circuit or injector #1 is defective.
Old Aug 25, 2014 | 09:16 AM
nitehawkjcb's Avatar
^agreed
Old Aug 25, 2014 | 09:18 AM
To our Expert Tech Member 03SSLE `Mike
Thanks again `Mike for always sharing & helping a Member(s)
Old Aug 25, 2014 | 09:27 AM
JoeD's Avatar
ok i have a extra injectors ill clean an then try that an see what happens but will that cause the car to shake real bad when tryin to drive even when sitting in park
Old Aug 25, 2014 | 01:12 PM
vikesfan's Avatar
Yep, it sure will
Old Aug 26, 2014 | 10:30 AM
JoeD's Avatar
Well I replaced injector 1 an still have the same problem I have a small exhaust leak that I notice from the rear to I have pacesetter headers what can I use to seal them it's between the heads an rear header
Old Aug 26, 2014 | 10:57 AM
gasman's Avatar
Use " the force"
Old Aug 26, 2014 | 03:33 PM
JoeD's Avatar
Anybody know what I can pick up at autozone or advance that I can USe instead of a gasket?
