2000 MC SS codes P0102 P0201 P0412
Old Apr 15, 2013 | 06:49 AM
phatboy313's Avatar
Default 2000 MC SS codes P0102 P0201 P0412
I just recently put new engine in my MC is it is running very sluggish and it misses at idle my check engine light is on the codes that are popping up are p0102,p0201, and p0412 any help will be appreciated!!
Old Apr 15, 2013 | 07:12 AM
03SSLE's Avatar
You are having malfunctions in the MAF, the injector circuit for cyl 1 & the secondary air injection valve circuits. My suggestion would be to double check all connections to insure they are all clean/tight. Then clear the codes and see if any come back. If they do then diagnostics of the individual circuits will be required to determine what is setting the code(s).
klkline50
Jan 27, 2015 06:55 AM
JoeD
15
Aug 28, 2014 08:41 AM
Endo
Jul 14, 2012 08:54 AM
bowtie8_3
Jul 20, 2009 07:24 PM
Jiggly
Oct 3, 2008 12:47 PM
