overheating , but should i put coolant in radiator or reserve tank
Old Jan 31, 2011 | 12:54 PM
Fill the radiator up, make sure the overflow is where it should be.
Bleed your system completely.
If you drove the car with it overheating, you could have warped something bad, so let's hope that didn't happen.
Old Jan 31, 2011 | 02:12 PM
cornerview's Avatar
ARG, CHIBI! u forgot to knock on wood! lol, . . . . just got a call from the shop. my radiator is leaking and he also "believes" some of that gunky crap got in my intake manifold. so they want to swap both parts out. along with a thorough power chain flush. boy this is gonna be a long week. thanks for all you guys help with this matter. i seriously cant put in words how much its appreciated! wish me luck as i plan on visitin my backyard mechanic who will do the work. ill give u an update on his opinion and a second update on his post work.
Old Feb 20, 2011 | 01:08 AM
rgant_19's Avatar
I am having an overheating issue with my MC as well. But, the thing is, I smell something burning by the serpentine belt (like burning oil) which I even tried to see if the coolant will flow inside the radiator with the cap off. Well, that was a bust!!! So imma just let the mechanic hit my pockets because I can't keep going through this.
Im going to buy a new radiator cap tomorrow to see if that is the issue!!!
Old Feb 21, 2011 | 08:37 AM
Could be the water pump, belt driven.
Old Feb 21, 2011 | 11:15 AM
rgant_19's Avatar
@ ChibiBlackSheep: I sure hope its something simple. I just dropped it off at the shop and the guy will let me know what was wrong with it. Check this out, he wil even throw in a scan code search to see what's faulty in my car. You can't beat that one....which is free
Old Aug 18, 2013 | 11:50 AM
Lorraine Jacklin Allen's Avatar
okay I have a question. I do body work and a little bit of engine work. but I replaced my t-stat already and the recovery tank also. I believe there are to hose on the recovery tank one in the front and one in the back. but I cant find the other hose. the system has to be pressurize for to work right. I cant find the hose in the back or were it might be located on the engine. it is a 01 monte carlo 3.4 block. I looked on the net but I seem to come up empty handed for the recovery tank. please help
Old Aug 18, 2013 | 03:30 PM
The recover/overflow tank has 1 thin hose that connects to the radiator. There is an outlet on the tank to exhaust excessive pressure or in a worst case, release coolant if the system is that over filled or pressurized.
el pachuco
Jan 3, 2015 04:11 AM
superrod29
Mar 20, 2013 12:01 AM
Scooby doo
Dec 29, 2009 05:02 PM
prodigynius
Sep 4, 2009 01:56 PM
zk6216
Feb 29, 2008 06:40 PM
