o2 monte ss problems help if anyone can
Old Nov 28, 2013 | 08:20 PM
superss's Avatar
Default o2 monte ss problems help if anyone can
hey monte guys whats up ? i got a o2 monte ss with a 3800 s/c complete swap and reflashed pcm set up for a 180 t stat and a 97 s/c engine and trans. but i got problems iv burned up 2 trannys and when its cold start the rpms go from 2000 to almost a stall then picks back up to 2000 or 2500. could this b a tps senser or the maf senser? i was told that the tps has something to do with the trans operation but im not sure. it also has a miss at idal the engine light is on and i got codes like 6 of them but ill post them later. any help would be good.
Old Nov 28, 2013 | 08:28 PM
l67ss's Avatar
I would check for a vacuum leak, that wouldnt cause your tranny issues but a vacuum leak could cause the other issues. Good luck
Old Nov 28, 2013 | 10:13 PM
superss's Avatar
thanks i will check it out
Old Nov 28, 2013 | 10:55 PM
l67ss's Avatar
If youre running a 97 tranny that would mean its a 4t60, that could b why youre killing them they are WEAK
Old Nov 28, 2013 | 11:53 PM
superss's Avatar
its a 4t65e-hd 02 from the car i made it a hd thats the one that just burnt up it had junk cluches and messed up parts in the valve body. getting another one and then changing the tps and the maf sensers and c what happens.
jaydflash
Aug 29, 2014 03:38 AM
JWS76Monte
Sep 23, 2008 11:53 AM
vincentvega
Jun 10, 2007 02:06 PM
