New parts?
Alright so im replacing my o2 sensor soon but im also replacing the ignition coils and lower control arms/balljoints. When we dropped the cradle to change the rear main seal it messed up my lower balljoints so my question is should i replace just the balljoints or would it be easier to change the whole control arm? Also for the coils should i go with GM coils or aftermarket?
GM coils for sure. Not sure about the lower ball joint but I would probably replace the whole thing that way the control arm bushings are new as well
Get a new control arm and sway bar link. Its really hard to just replace the ball joint. The sway bar link is usually toast when you try to pull it out of the control arm. Just keep in mind with the new bushings you may be looking at an alignment. Dealing with that on the way to work today O.o
IMO, unless you have a problem that is definitely your coil packs, there is no reason to change them. 90% of the time, they last the life of the car. GM has used these coils since the early-mid 90's and I've had some and seen plenty over 200K miles, no issues all original coils.
As for the ball joint on the control arm. I've changed that ball joint on my old '94 Grand Am as well as the vertical bushing. The process on that car is the same as the Monte. Drill out the rivets on the old ball joint, put the new one in, the new one comes with a kepts nut and bolt set to use in place of the rivets. Works with no issue. But the bushing is a PAIN without a press. I would price a new control arm and consider it, as replacing it should be quicker, easier and as mentioned, all new. I also had an old control arm (about 190K miles) break due to rust. Not fun!
As for the sway links, that is a GREAT idea. Normally by the time you go to remove them, no chance in hell getting them off the car and the rubber bushings are normally cracking anyways.
There should be no need to alight the vehicle if you are changing the control arms or the sway bar end links. These do not have alignment adjustments to them. Any alignment changes they might cause should be minimal and again, not warrant an alignment.
Well I am having about a 3-4 degree alignment issue that started the day after doing my CV, control arm and sway bar link. Maybe its just coincidence. But the car felt kind of squirrely on the way to work today.
Well guess ill have to check everything today
I agree with John. So as long as you did not mess with those items, the alignment should not be affected. The ONLY other thing I could suggest is that the last time the car was aligned, the parts you changed worn ridiculously out of spec and the shop that aligned it did not properly inspect those parts prior. Otherwise any impact those parts have on the alignment is minimal to none (in most normal cases).
Also sorry to jack your thread dude.
