need help any ideas?
Old Oct 12, 2010 | 02:55 PM
needasmoke24's Avatar
Default need help any ideas?
got a 96 monte with 3.1 leaks coolant when hot, it doesn't seem to be the intake manifold gasket, its leaking behind the water pump hosing but I can't pinpoint this darn thing. any ideas? man I am getting fustrated....Thanks Troy
Old Nov 28, 2010 | 10:00 PM
bustedgto@live.com's Avatar
it is most likely the water pump
Old Nov 28, 2010 | 10:21 PM
zipper's Avatar
Agreed, it probably is but you won't know for sure until you do a pressure test on your coolant system.
Old Nov 28, 2010 | 11:07 PM
I agree, sounds like the seal to the pump went out. When this happens a small factory made hole permits small amounts of coolant to escape. The pressure test will be the ticket.
Old Dec 6, 2010 | 11:44 PM
Default thanks all
it had a crack in the timing cover, pulled one out of a bone yard for 20 bucks problem solved.....
kingreyna
Apr 19, 2009 07:51 PM
tdunbar5
Sep 22, 2008 05:55 AM
v8_Killa
Feb 21, 2008 02:16 PM
vita
Dec 23, 2007 04:18 PM
vita
Oct 21, 2007 12:17 PM
