Is my tranny going out
Just to add...my Monte started having slip and shift delay issues about 6mo. ago, and just the other day began to slip from a stop, then to the point of not going forward unless I put the shifter into 1st or 2nd. As I had guessed...when I dropped the pan, I discovered that my forward band had broken.
when was the last time you did a drop pan and put in a new filter and fluid? mine did some thing similar till I did a new filter and new fluid. I would do a service like that see if it would clear it up if not it might be a solinoids. but droping the pan might give you some sight on whats going on in there.
slinkeey
Feb 3, 2009 10:33 AM
