Is my tranny going out
Old Mar 21, 2014 | 10:26 PM
BrandonStebing's Avatar
Default Is my tranny going out
2003 monte ss, shifting ruff, and hesitating at times. Anybody know what's wrong? Or anything I can do to make it run/shift better.
Old Mar 21, 2014 | 11:58 PM
turbo monte's Avatar
Could be the solenoids in the trans. Any engine codes for these symptoms?
Old Mar 22, 2014 | 01:51 PM
owens91's Avatar
mines does the same thing, i suspect mines could be the solenoids and maybe the torque converter
Old Mar 22, 2014 | 02:58 PM
seen03's Avatar
Just to add...my Monte started having slip and shift delay issues about 6mo. ago, and just the other day began to slip from a stop, then to the point of not going forward unless I put the shifter into 1st or 2nd. As I had guessed...when I dropped the pan, I discovered that my forward band had broken.
Old Apr 4, 2014 | 03:09 PM
monte07's Avatar
when was the last time you did a drop pan and put in a new filter and fluid? mine did some thing similar till I did a new filter and new fluid. I would do a service like that see if it would clear it up if not it might be a solinoids. but droping the pan might give you some sight on whats going on in there.
Old Apr 12, 2014 | 08:09 AM
johnniep's Avatar
i had to replace the solenoids.....fine now
70monte1
May 12, 2011 07:40 PM
Budsjlm
Nov 29, 2009 06:33 PM
slinkeey
Feb 3, 2009 10:33 AM
dustybird3
Jun 9, 2008 01:22 AM
dustybird3
Feb 17, 2008 08:13 PM
