7th Gen ('06-'07): motor mount
Old Aug 9, 2014 | 08:57 PM
bigjon30's Avatar
Default motor mount
I've seen some people say they have flipped the front motor mount to stop the engine from flexing as much. I'm just wondering if it really makes that much of a difference or if it is safe to do. Thanks
Old Aug 9, 2014 | 10:01 PM
vincenti's Avatar
It's makes & difference & is easy 2 do. Use WD40 & rotate it 90 degrees. If u got a few $$$ invest in a poly
Old Aug 10, 2014 | 10:28 AM
bigjon30's Avatar
Is it completely safe to do?
Old Aug 10, 2014 | 07:22 PM
About the only thing that might not be 'completely' safe is that you might squirt some WD-40 in your eye during the procedure, lol. Really there is virtually nothing that can go wrong. Best part is, if you don't like it, just rotate it back.
There is a small difference, and it's definitely worth the 10 minutes it takes to do, especially since it's free. It's nowhere near as big of a difference as poly replacements though.
Personally, I'd rotate them- and if it doesn't stiffen up enough, then go buy polys. Worst thing that could happen is that you wasted 10 minutes or so.
2003supersport
21
Apr 29, 2009 02:06 PM
2003supersport
Feb 4, 2009 09:15 AM
HyperFox
FWD Tech Guides '95-'07
14
Nov 7, 2008 12:18 AM
odessadude
Feb 2, 2008 07:23 PM
GooberMT
24
Sep 26, 2007 09:06 PM
