7th Gen ('06-'07): motor mount
About the only thing that might not be 'completely' safe is that you might squirt some WD-40 in your eye during the procedure, lol. Really there is virtually nothing that can go wrong. Best part is, if you don't like it, just rotate it back.
There is a small difference, and it's definitely worth the 10 minutes it takes to do, especially since it's free. It's nowhere near as big of a difference as poly replacements though.
Personally, I'd rotate them- and if it doesn't stiffen up enough, then go buy polys. Worst thing that could happen is that you wasted 10 minutes or so.
2003supersport
Feb 4, 2009 09:15 AM
