6th Gen ('00-'05): 3.4 liter Cooling fan replacement
Old Sep 27, 2012 | 08:24 PM
wtxbear's Avatar
Default 3.4 liter Cooling fan replacement
So the A/C condenser fan was acting up and sounded pretty bad. I popped the hood open to take a look and found that a plastic bag had been sucked between the headlight and had gotten caught around the fan shroud and prety much eaten up. In the process the blades were torn apart causing the entire housing to shake. So this weekend ill be replacing both fans. Has anyone done this? Pretty easy to do? or just let a mechanic do it? Any Tips?
golf0982
Jun 4, 2009 06:29 PM
zk6216
Apr 13, 2008 02:49 PM
blazerman3
Mar 20, 2008 06:50 PM
seth_06
Dec 2, 2006 05:42 PM
