lower engine mount
Old Jun 21, 2010 | 10:28 PM
machine2950's Avatar
Default lower engine mount
hi everyone ! living in montreal quebec and having hard time finding performance parts for my car (monty 04 sc) im looking for the lower engine mounts would like to have thems in poly ??? or if solid is good too!
Old Jun 22, 2010 | 07:18 AM
Stevis's Avatar
Old Jun 22, 2010 | 11:45 AM
i would check with their shipping first, but i think theyd be able to ship there, itd just cost a little more.
Old Jun 22, 2010 | 07:11 PM
Any particular reason? Have you already done poly upper mounts (those would be much easier to swap first to see if you like all the added vibration)?
I just think if its your daily driver and your stock lowers are shot I'd probably get some OEM replacements rather than spend almost $300 (by the time you add shipping) on the poly lowers- plus that would suck if you couldn't stand the vibration.
Old Jun 23, 2010 | 11:31 PM
yes i put the upper in poly and get thems from ZZP ! but never see the lower one in poly,it vibrate a bit. just got new one from GM . btw what do you think of meth injection kit ?(snow performance 20012) thank u !
Old Jun 24, 2010 | 12:11 AM
nemesis's Avatar
2009 Monte Of The Year
zzp poly mounts are junk. intense-racing are way better. it's softer and does not vibrate as bad as the one from zzp. my first set was from zzp, now i have intense and very minium vibrate than zzp poly mounts.
i do full size intercooler over meth or snow performance.
here's a canada vendors. he does some products for zzp too.
http://www.getoverkilled.ca/products.html
Old Jun 24, 2010 | 09:51 AM
thank u to all of you! it s seem that quebec its not on the map sometime to get performance parts!
Old Jun 24, 2010 | 07:05 PM
Could you imagine both upper and lower from ZZP at once though lol
I assume you're supercharged?
IMO, if you don't have a lot of mods already- there is probably still a lot you can do for the price of a good meth kit that will gain you permanent power that never needs refilled, and never has a pump to go bad (ie rockers, headers, pulley, TB, ported SC, etc)
Old Jun 26, 2010 | 12:13 PM
cool bumpin now im looking for headers i really like the slp but there expensive,also find the pace setters they look ok and the last one are from speed daddy (cheap) already swap the pulley+cold air+pcm flash+u bend+delete+colder plug,
u were right it s a chance i didn t find the lower mount in poly !!!
Old Jun 27, 2010 | 12:07 AM
If speed daddy's are what I think they are, I believe they're the same header as the SSAutoChrome or XSPower (or DPP for that matter)- basically just a ripoff of the SLP design (I have the DPP's, and they're ok).
You've got to be careful with pacesetters- they used to only sell the ones with 1 3/4" primaries- which is awfully big for a mildly modded 3800 IMO. They now sell a 1 5/8" version (which is what all the other 3800 headers are outside of the TOG extreme and big dogs) though. Also, they used to have a problem with the slip fit- they were over expanding the one pipe, so it was difficult to make them seal up at the Y collector. They have fixed the problem now, but that doesn't say much for those who still have old stock left. Plus pacesetters aren't stainless either.
