K&N for the 2006 V8 SS
Old Apr 16, 2008 | 01:29 AM
bwill314's Avatar
Default K&N for the 2006 V8 SS
Does K&N make a cold air kit for the 2006 SS V8?
If so, will this void my warranty?
Old Apr 16, 2008 | 10:56 AM
TonySS2007's Avatar
Default RE: K&N for the 2006 V8 SS
Hello,
Yes K&N does make a aircharger here is the URL http://www.knfilters.com/search/prod...x?Prod=63-3059
As far as the warrenty, I don't think it would do anything, but I would call the dealership to make sure before you do anything.
Old Apr 16, 2008 | 03:30 PM
big_mecho13's Avatar
No it does not Void the warranty. The dealer could give you **** about it, just call GM customer service and complain see how vast they will change their story. or you could go to a different dealer.
I had no issues with service after putting the air charger.
A few of the techs went to look at it, and I was asked if I instaled it myself, then the tech said he uses K&N filters in all his cars and that was that.
You can also have K&N call your dealer http://www.knfilters.com/MAF/massairpledge.htm
Old Apr 16, 2008 | 05:55 PM
DEI Monte SS 04's Avatar
I bought a K&N from Autoanything.com for $206 shiped to me. (Hope that helps you out)
I installed it about 1.5hrs. Then now when I start the car for about 40 seconds it sounds like it is sucking in alot of air (loud) then it calms down and goes back to normal. Anybody else get this condition. Is this normal?
Old Apr 16, 2008 | 09:02 PM
bwill314's Avatar
big_mecho13,
Is that your car on the picture? Where did you get the grill?
Old Apr 21, 2008 | 11:03 AM
bwill314's Avatar
Another question:
When I get one, where do I go to get it installed? I am in the St. Louis area, so if you aren't from here you can't give me an address of a shop, but will any shop install this? Is it easy to find a shop to do this or not.
Old Apr 21, 2008 | 12:48 PM
It is a easy install with some hand tools. You will have it installed before you find someone to do it.
Slugger088
Sep 9, 2011 07:24 AM
Boost
Oct 24, 2006 05:48 PM
MsBeanCtr
Mar 9, 2006 03:07 PM
bloomquist0
Jan 16, 2006 10:45 AM
montejass
Apr 5, 2005 09:13 PM
