Opinion Needed: I need help with a belt setup!!
Old Sep 3, 2014 | 09:53 AM
03vaderSS's Avatar
Exclamation I need help with a belt setup!!
Hey guys my car is in the shop to install the heads and cam and oversized radiator. I am also going to have my mechanic run a belt setup to the front of the engine bay. I emailed zzp for a diagram and they said type in gtp belt setup as it shows how to do it. Should this be sufficient? Are there any other parts I will need?
Old Sep 3, 2014 | 02:45 PM
turbo monte's Avatar
Not understanding what you mean by belt setup to the front of the engine bay....
Old Sep 3, 2014 | 02:47 PM
03vaderSS's Avatar
How stock montes or even gtps that are supercharged. The pulley has the belt to the front of the engine , google 04 mcss sc image
Old Sep 3, 2014 | 02:49 PM
You asking for the supercharger belt routing diagram? If so yes it's all the same between gtp and montes
Old Sep 3, 2014 | 03:25 PM
03vaderSS's Avatar
Ok thanks
Old Sep 3, 2014 | 05:22 PM
Old Sep 4, 2014 | 02:45 PM
z34phoenix's Avatar
it sounds like your trying to add a second belt so that you can run a SC... if you dont already have a SC then you have the NA version and you cant just drop a blower on and run a belt and be done. you mention heads. the SC'd engines need SC'd heads cause the NA engine has fuel injectors in different locations then the SC'd ones. also the Harmonic Balancer is different on the SC vs the NA. the SC has a second row of ribs to drive the other belt. if your car is 99+ you will need a diff coil pack to hold the idler and tensioner pulleys for the SC also.
if you could give more info on what your attempting to do, we can better help you.
anaconda44
Feb 23, 2013 12:11 PM
JCoxx93
Mar 15, 2012 02:14 PM
denny8569
Feb 14, 2010 12:12 AM
travisgunter0
Aug 14, 2009 09:29 PM
Pure2sin
Aug 3, 2009 11:46 AM
