Possible Upgrades? Good setup help?
Old Mar 15, 2012 | 09:51 AM
JCoxx93's Avatar
Default Possible Upgrades? Good setup help?
Considering some new mods... Need some info from you guys that have more modding experience than me to decide on a good build, but that can also still be used as my dd. Put in your opinions as I want a high hp/torque build. Will be having a custom tranny built soon hopefully (3.69 gearing and 3000 stall converter?)(hardened input and outputs and hardened 4th gear)...
Considering:
New Cam (maybe the XP one on ZZP)
Cartuning's Turbo kit
1.9" Rockers? (should I use with cam?)
New Headers
A lot of exhaust work to end up with no cat and 2.5" straight to 4" tips
Possible Intercooler
Forged Heads
Springs
Lifters
Axle Upgrade
Old Mar 15, 2012 | 10:04 AM
It is either Rockers or Cam. Not both.
The turbo kit would give you the exhaust manifold changes, you don't run the turbo with headers. A ZZP Front Exhaust PowerLog is good for turbo builds.
Again the turbo would have the downpipe, so you would just need the turbo downpipe to be cat-less.
Remember if you get the different gearing you will need to have that in the tune also.
Old Mar 15, 2012 | 12:43 PM
JCoxx93's Avatar
Which actually do more for you? Rockers or Cam? Plus will rockers still give me the wobbly idle of a big cam?
Old Mar 15, 2012 | 02:14 PM
CAM has better gains, but a longer/harder install.
Rockers won't give you idle lop.
03vaderSS
Sep 4, 2014 02:45 PM
denny8569
Feb 14, 2010 12:12 AM
travisgunter0
Aug 14, 2009 09:29 PM
jessymo
Feb 19, 2009 10:07 PM
jaws2008
Nov 14, 2008 01:02 AM
