6th Gen ('00-'05): here we go again :( another trans toast :(
Old Sep 20, 2013 | 09:08 PM
turbo monte's Avatar
Default here we go again :( another trans toast :(
as you all know i am making a lot of power and with a lot of power things like to break.... unfortunately for me they are breaking almost every time i drive the car
so i am getting ready to build trans 4! i took turbo monte out wednesday and made some highway pulls and she was running great, i come home and shift into reverse and i have nothing so i shift into D and have nothing..... it will move but hardly at all its slipping very bad. so i narrowed it down to the ratcheting sprags in the trans locked up and it fried the input clutches hence why it drove fine until i came to a stop
so now for the good part, while it is out getting rebuilt i am upgrading more parts that i have finally found a source to getting my hands on some of you may know what these parts are and if you do and you dint have them you will probably be jealous and if you do have them you know why others will be jealous and if you dont know what these parts are and you plan to make over 500whp i suggest researching it and trying your best to find them
now onto the list of goodies.....
aermet GMR 800hp input shaft
GMR 300m output shaft
GMR torsen diff
GMR 1" 3/8" pitch (secret and rare gear ratio) chain set (i have a 1" 7/16" pitch 3.52 gear ratio chain set i am simply switching because i want the different gear ratio)
i will be going to the earlier design sprags which are better to help prevent the failure that has happened and also replacing input clutches, 4th clutches and 4th hub. if second and third clutches show wear they will be replaced as well.
this set me back a step i didnt want to have happen, i was getting ready to buy a complete aitr bag setup but now money goes to a trans instead.... o well these parts i am getting are well worth it
FYI ALL OF THE GMR PARTS ARE DISCONTINUED YOU CAN NOT BUY THEM ANYMORE
I will keep you all posted once i decide to tear the trans out once again..... im getting tired of working on it
as ive always said and been told... big hp=big money
Old Sep 20, 2013 | 09:10 PM
Must have been that wedding burnout
Old Sep 20, 2013 | 09:14 PM
John:
Sorry to hear about the trans takeing a dump on your parade!
I hope its an easy fix once you get the right parts for it! Good Luck!!
Keep us posted.
Thanks for shareing the HP info!
Old Sep 20, 2013 | 09:27 PM
lol nah it wasnt the wedding burnout it was when i raced or in better words crushed a new malibu ss on my way home the night this happened. thats when i think it happened lol not saying the burnout didnt play a part in it though
its all in all an easy fix and a cheap fix if i would just fix it but while i am in there i am upgrading all the hard to find parts i finally found which makes it an expensive fix lol.
in all honesty i could have it fixed for about $300 in parts at the most but with all the parts i decided to upgrade im looking at around a $3500-4000 rebuild, although i will be able to sell my 300m input shaft and my current GMR 1" to offset some of the cost which is a good thing. and for anyone wondering i am 99% sure i have my current 1" chain set sold and its not even out of the car yet
Old Sep 20, 2013 | 11:47 PM
Dude, that is sucking!!!
I don't follow a lot with the transmissions on these (other then I know they are a weak spot). In brief, how does the current trans build you're going for stack up against a built trans from T.E.P.?? I'm assuming the end result you're hitting is better in cost and quality then T.E.P....
Old Sep 21, 2013 | 05:00 AM
The trans build I have and I am building now are both better than TEP because I sourced the GMR components. TEP can not get GMR components. Now for the other parts like the valve body and Chanel plate upgrades, clutches etc all of this I bought from TEP.
TEP builds an awesome trans, I would recommend anyone to him!
Old Sep 21, 2013 | 06:29 AM
I'm sure TEP will be getting my money in a couple of years... haha
Old Sep 21, 2013 | 07:54 AM
I agree with that with your build. You should start sourcing a 1" chain set now and start a savings fund for a trans build haha
Old Sep 21, 2013 | 08:14 AM
Thumbs up "The Cost of POWER" > $ < ? > WoW <
Hi `John,
Sorry to read about another transmission dump'in on you
Sadly > POWER COST > BIG TIME $'s 2 have `Fun...
It seems to be a never ending expense, but it's sure super fun to be in control of ones Power & hook `up & beat the competitor's that challenge your machine
Some fun cost more then other fun & there always seems to be other's that come along with more power to challenge your machine.
It's a never ending cost, but it's never ending fun as long as you can afford to stay in the Performance Game. > I wish you good luck on getting your machine built better then b-4 & the race continues...= = = = = = = == = = = =
EnJoy your Power & Good Luck
jwjones
Jan 11, 2012 08:25 PM
WannaMCSS
Dec 14, 2011 09:27 AM
acerocks666
Oct 12, 2011 05:33 AM
chevybaby
Nov 18, 2010 11:34 PM
J_Bru_Ha_SS
Dec 3, 2006 10:19 PM
