Halfway through some upgrades - is this normal???
Old May 29, 2010 | 07:15 PM
davidk67's Avatar
Default Fixed - Halfway through some upgrades - is this normal???
Well tonight I decided to get into the engine and swap out the stock plugs and wires. So far I have only done the front half, and put some minor abrasions and bruises into my hands doing so.
I did the front wires - PRJ's, and the plugs are NGK's. The question I had, is when I started it up to move the car back to its normal parking spot - the sun has dropped and the mosquitos are busy attacking my exposed areas for a blood feast - the engine was very rough at idle, and shook a little bit as I moved it about 15-20 feet or so to its parking spot. Will this go away when I put in the other 3 matched plugs and wires? Or is there something I missed with the three I did put in.
The wires are seat on both the plugs and the coil firmly.
I appreciate any opinions. Thanks in advance.
Old May 30, 2010 | 03:00 AM
montecarlo01ss's Avatar
check the plug firing order.. sounds like its misfiring. check gap? plug boots snug?
Old May 30, 2010 | 05:05 AM
nemesis's Avatar
2009 Monte Of The Year
what he said ^^^^think you mix up the wire and put in the wrong cylinder.
Old May 30, 2010 | 02:14 PM
davidk67's Avatar
went out and checked the wires and coils again this am, yep it was a switched pair of 3 and 5.
runs as it should now.
I thought I did these as 1 wire/1 coil at a time. guess one wasn't.
Old May 30, 2010 | 06:40 PM
monte07's Avatar
dont fret i think every one has done that before as a ups in a way i think i did that when i did my first v6 chevy so dont feel bad. what i am saying we all do a little miss hapes now and then if we dont how can we learn from them
VictoryRedSled
Jun 18, 2014 04:33 PM
Habbibie
Sep 13, 2012 06:02 AM
blackmonte781
Apr 30, 2012 11:48 AM
BlarneyStone13
Nov 11, 2010 02:39 PM
k_johnston18
Mar 22, 2008 02:28 PM
