good price on a S/C
i also second the turbo speaking from a guy that has a turbo monte. turbo cars have so much more potential, and under low boost still very reliable. i just dynoed my monte saturday and put down 384whp on 13lb boost, i probably could of hit 400whp but ran out of maf. this was on the cartuning performance kit with only the precision pt61 turbo. as far as transmissions go triple edge makes good trans. i had mine built by tim king he is way cheaper and builds an awesome trans as well. he is located in ohio.
Cartuning Performance
Do you need anything else besides this or is everything included? I'm assuming this is what you have.
that is everything you need, even comes with a new pcm and he takes yours for a core or keep yours also and eat the core charge. i also highly recommend an intercooler kit. with an intercooler you will be able to run more boost safely and make more power. you can make a intercooler kit way cheaper than what he or zzp charges for them also. i ran 10lb of intercooled boost on stock engine and trans for 7,000 miles before my torque converter finally went out on me. if u ease into the throttle till u hit wot and dont launch the car or do massive burnouts your trans should be ok for a little bit. but there is no guarantees how long it will last. that kit alone will put your car right around 300hp. i suggest getting the electronic cutout with it. the cutout makes a huge difference in spool time etc. i also suggest a set of aeroforce scan gauges just so you can monitor for knock etc. i just uploaded dyno videos of my car in the sights and sounds section if u wanna check them out. my personal opinion i love the sound and feel of a turbo over a sc. the feel is so much better because when u hit the gas the car starts going and then in a second or 2 when u build boost its like a rocket and u actually feel the difference, with a sc the power is instant so u dont get the feeling lol. dont get me wrong thou ive been in some fast and fun sc cars also!
he is a big clubgp member, he costs 1400 with all upgrades but input shaft. if u want the input shaft upgraded he charges 1800. plus shipping of course. i bought all my own parts and took them to him so mine was alot cheaper. for my trans he supplied the rebuild kit with clutches and bonded pistons, all sensors, shift kit, valve body upgrades and input piston. he charged me $850
Ace_5600
09-23-2008 11:24 AM
