WHAT DO YOU THINK ABOUT THIS?!?!
Old Mar 17, 2008 | 12:37 AM
sinceire's Avatar
Default WHAT DO YOU THINK ABOUT THIS?!?!
Im currently thinking about adding some mods to my engine (https://montecarloforum.com/m_83210/tm.htm) but am unsure if I should ad mods to it or get a new engine and when I saw this I was like wow, but I know theres a catch.... What do you think?
http://www.wbodystore.com/grandprix/...sed-p-230.html
Old Mar 17, 2008 | 12:51 AM
sinceire's Avatar
Default RE: WHAT DO YOU THINK ABOUT THIS?!?!
My logic is saying this, the engine has ALOT less mi than my current one (lol) The supercharger alone cost a whole lot more than there selling the engine. But I am curious as to whay type of supercharger comes on these engines?
Old Mar 17, 2008 | 01:15 AM
rysZ34's Avatar
ORIGINAL: sinceire
On the series II 3800 they had an Eaton M90 installed. Check out this link from the Eaton Corp.
http://www.eaton.com/EatonCom/Produc.../M90/index.htm
Also,
"This engine has ~10,000 miles on it and ran well before a rocker bolt snapped."
That quote tells me that something isn't right, either the motor was abused, or the motor can't handle the mods. You will need heavier rockers and probably an ECM flash to handle the cam. Just be cautious and find out as much as you can about this motor. I'd hate to see you spend the money and get a motor that won't run correctly. Good Luck!
Old Mar 17, 2008 | 04:16 PM
You do realize that is just a shortblock right? IE- its just a block, pistons, rods, crank, front cover, cam, etc- there are no heads, no supercharger, no anything else.
So if you put this in your car, you're goign to add a very tiny bit of power from increasing from your current 9.4:1 compression to the 9.5:1 that comes with (plus a tiny bit more power from being bored .020 over).
I dunno if the cam would help or hurt you-its a very mild cam made for a supercharged engine, so unless you plan to add a supercharger, I don't think it would help you much being NA.
Personally, I wouldn't say theres a catch at all. I know its a lot of money into it (figure $800 for the pistons, $750 for machine shop work, $300 in stock parts like the block and such, $100 for the head studs (minus nuts), and $300 for the cam- but it is a used engine. Not to mention rebuild 3800s are not very desireable at all. I'd be very weary of it unless they gave you the information about the shop- and it was a shop that has rebuilt 3800s before. These aren't as simple to rebuild as many machine shops think they are- and many end up spinning bearings and such. So I actually think $1200 for a short block from an unknown engine shop is actually pretty high priced IMO.
edit- not to mention it says there is absolutely no warranty- if you spend all day putting this thing in and it spins a bearing in the first block you drive it- you're screwed.
Old Mar 18, 2008 | 11:40 AM
sinceire's Avatar
ORIGINAL: bumpin96monte
Thanks, thats why I asked, I really dunno about all that stuff man Im still learning about these engines and everything. I just saw it and was like wow, I knew there was a catch!
Old Mar 18, 2008 | 05:48 PM
rysZ34's Avatar
Boy, bumpin' I read that wrong too. lol. But I do agree with you, an unknown machine shop, no warranty...probably not a good idea. Good points brought up!
Mr.Monte
Aug 31, 2012 07:55 PM
BlackRainSS
Feb 4, 2012 04:09 AM
The Popcorn King
Aug 21, 2009 09:34 PM
roadshoptuner
Aug 4, 2006 07:32 PM
big green dog
Apr 24, 2006 05:25 AM
