6th Gen ('00-'05): Fuel system issues
Old Dec 16, 2012 | 08:46 PM
Bhone's Avatar
Default Fuel system issues
Been having alot of issues with fuel pressure suddenly. Jumped in after driving all day and couldnt start. Had no issues before this. Only 1 check engine code p0420 catalyst system. Got a cat back and replaced o2 sensors and it was fine. So far ive Replaced the fuel pump, filter, and pressure regulator.
Now im stumped on what it could be. Pump was replace once before by prev owner 2 yrs ago.
Sprayin starter fluid in throttle body gets a start but it dies as soon as fluid burns off.
Any ideas on a possible problems ?
Old Dec 16, 2012 | 10:03 PM
nitehawkjcb's Avatar
My guess would be a crank sensor or MAF sensor. Unplug the MAF and see if it will start.
If it's getting fuel pressure, then it could be what I mentioned or the Ignition Control Module.
Old Dec 17, 2012 | 06:31 AM
Bhone's Avatar
Still no start ,it cranks but sounds like its not getting gas fuel pressure still too low. I cleaned the maf and throttle body as i was taking them off to replace the regulator. Not really a way to check the position sensor but it should have thrown a check engine code right ?
Old Dec 17, 2012 | 10:39 AM
No, I had 2 crank sensors go bad on me and not a single code for either.
You need to test the fuel pressure to see how much you're getting.
ReaperSS
Oct 26, 2014 09:33 AM
AAGL
Apr 19, 2014 09:43 AM
Monte_Man04
May 19, 2012 03:28 AM
netz111
Aug 4, 2011 07:18 AM
J_Bru_Ha_SS
Aug 16, 2006 04:03 PM
