Engine Tick/Rattle
So, I took my Monte in to be inspected and have the oil changed here at the local Chevrolet dealer last week. They inspected hoses, mounts, belts, etc and they all checked out. I had them do a full synthetic oil change and they showed me I have a minor oil leak and I need to replace the pan with the new aluminum one and replace the gasket, which is no big deal. The leak is so small its not dripping on the ground or anything so they said I have a while before needing to do so. That's all fine dandy, but my issue now is on my way home and everyday since last thursday there is a ticking that sounds like its coming from the back of the engine bay. It is only at idle and up to 1500 rpms that I hear it, it just sounds like shaking a spray can. The car doesn't drive any different but it's just annoying. Maybe a lifter? I don't know what kind of oil was in it before. Probably wasn't synthetic I'm thinking. Any advice is welcome.
![EEK!](https://montecarloforum.com/forum/images/smilies/eek.gif)
If your comfortable removing the valve covers and checking it out, then go for it. Despite the cost, a dealership or shop may be your best bet if this line of work scares you. No offense, just not sure what kind of mechanical skills or experience you have
![Thumbsup](https://montecarloforum.com/forum/images/smilies/thumbsup.gif)
I find the oil pan leak a little, say suspect?? Unless you hit the pan on something or it rotted out, typically you DON'T need to replace the pan or it's gasket.
Perhaps the o-ring/seal on your drain plug needs replaced OR more likely is an upper oil leak (such as a valve cover gasket).
As for the ticking, that is a bit odd. 3100/3400's are KNOWN for cold start ticks, but the 3800, no so much. Check if anything is loose or failing exhaust gaskets. Hopefully it's something small and minor.
![ROTFL](https://montecarloforum.com/forum/images/smilies/lmao.gif)
6th Gen ('00-'05): 3.4L engine tick/ L67 swap
Jokers1995
08-19-2013 07:49 AM
montecarloLS350
09-30-2011 01:32 PM
irulesoha
03-01-2010 11:00 PM
