Engine swap question (wiring)
Old Sep 21, 2009 | 01:05 PM
Doug's Avatar
Default Engine swap question (wiring)
We're about to swap a 1988 vintage motor into a 1986 Monte Carlo chassis. Both cars are Super Sports. The question is will the wiring of the '86 chassis accept the 88 motor with it's stock wiring (to include the distributor and external coils) as is, or will modifications be required?
Thanks.
Doug
Old Sep 21, 2009 | 01:30 PM
The Popcorn King's Avatar
Welcome Doug
YOu will have no problem dropping the "NEW" V8 in the the 86. Your going to have to use the old distributor ( the on thats already in the car ). Its a really easy swap. Just make sure you use everything from the old block.
Shouldnt take you more the half a day to pull out the old block, swap things over and drop it back in ( is used to do it when i was a younger all the time ).
Old Sep 21, 2009 | 01:50 PM
Doug's Avatar
Thanks. I figured the '86 distributor would likely have to move to move to the '88 motor, That swap aside, are all the rest of the electrical connections compatable?
Doug
LW57912
17
Dec 29, 2013 05:27 PM
Staind413
Jul 2, 2011 12:27 AM
Robkeith2007
Jun 16, 2010 07:56 PM
retr0kickz
Jun 22, 2009 10:05 PM
allstar_jessica12
Apr 10, 2009 07:14 AM
