95 Monte ls swap to l67 , wiring obd to read obd II
Old Jun 6, 2010 | 01:54 PM
Robkeith2007's Avatar
Default 95 Monte ls swap to l67 , wiring obd to read obd II
Hi I am new here and was wondering If anyone has rewired an obd port ... I have a 98 Monte 3.8 harness and zzp l67 swap kit, what else do I have to do to make the obd port functional so I can plug in my aeroceptor n scan KR
Old Jun 14, 2010 | 03:16 PM
Has anyone done a 95? Any help would be greatly appreciated.
Old Jun 14, 2010 | 06:28 PM
As far as I know, the OBD 1.5 plug in the 95's is the same as the OBD 2 plug, you may just need to add some wiring. Sorry I don't have my repair manuals with me, or I'd look up the pinouts for you. It has been done before though.
Wikipedia does have information about the pinouts of each connector though (although you probably won't use all the obd 2 stuff):
For ALDL connections, pin 9 is the data stream, pins 4 and 5 are ground and pin 16 is battery voltage.
SAE J1962 defines the pinout of the connector as:
1. Manufacturer discretion. GM: J2411 GMLAN/SWC/Single-Wire CAN.
2. Bus positive Line of SAE-J1850 PWM and SAE-1850 VPW
3. Ford DCL(+) Argentina, Brazil (pre OBD-II) 1997-2000, Usa, Europe, etc.
4. Chassis ground
5. Signal ground
6. CAN high (ISO 15765-4 and SAE-J2284)
7. K line of ISO 9141-2 and ISO 14230-4
8. -
9. -
10. Bus negative Line of SAE-J1850 PWM only (not SAE-1850 VPW)
11. Ford DCL(-) Argentina, Brazil (pre OBD-II) 1997-2000, Usa, Europe, etc.
12. -
13. -
14. CAN low (ISO 15765-4 and SAE-J2284)
15. L line of ISO 9141-2 and ISO 14230-4
16. Battery voltage
The assignment of unspecified pins is left to the vehicle manufacturer's discretion.
Old Jun 15, 2010 | 09:15 PM
Ok thank u for the info. I hope I can get it to work. I have cold air, plugs, tstat, headers and 3 inch exhaust, zzp PCM, 10.3 mm wires, 3.4 pulley. This pretty much came as a package, The KR should be ok with the package right or wrong? Also is nos a bad idea on these l67 motors ?
Old Jun 16, 2010 | 10:35 AM
Is the motor still pulled? Good time to cam it, or at least get some rockers in there for the 3.4 pulley.
Old Jun 16, 2010 | 07:56 PM
Ya it is still pulled ... I was waiting on the headers before I bolted it all in, how hard is it to change the rockers, I'm not a mechanic but as far as I can see switching motors n tranny's isn't all that hard cause I grew up around all this but when it comes to ripping an engine apart I'm clueless, I am changing the valve covers to polished aluminum though so it'll already be open
vindicator
Aug 22, 2014 12:11 PM
oscar sanchez
Apr 23, 2012 11:20 PM
oscar sanchez
Apr 3, 2012 08:48 AM
shingding88
Aug 20, 2009 05:58 PM
2000_BLACK_SS
Jun 1, 2009 07:35 PM
