egr piping
I'm looking for an easy way to remove the egr piping so that i can clean it without having to remove the throttle body or moving part of the exhaust, does anybody know a way? btw its on my 2001 monte carlo ss 3.8L
If you just cleaning it, remove the egr valve and use a pipe cleaner or coat hanger and carb cleaner in the tubes. Is there a reason you need to clean it? I've yet to see a 3.8 liter with plugged up egr passages and I've worked on a lot of them.
7th Gen ('06-'07): custom exhaust/ piping / mufflers
Anton Steichen
May 3, 2013 11:07 AM
Skeletal Crow
May 20, 2011 06:49 AM
