egr piping
Old Sep 5, 2010 | 08:42 PM
HanginAndBangin's Avatar
Default egr piping
I'm looking for an easy way to remove the egr piping so that i can clean it without having to remove the throttle body or moving part of the exhaust, does anybody know a way? btw its on my 2001 monte carlo ss 3.8L
Old Sep 6, 2010 | 12:55 PM
labnjab's Avatar
If you just cleaning it, remove the egr valve and use a pipe cleaner or coat hanger and carb cleaner in the tubes. Is there a reason you need to clean it? I've yet to see a 3.8 liter with plugged up egr passages and I've worked on a lot of them.
Old Sep 6, 2010 | 02:13 PM
Enzo354's Avatar
STILL SLOW
I just took mine out and put on block off plates. Easier than cleaning and looks much better
Old Sep 6, 2010 | 05:11 PM
monte07's Avatar
i think he is doing perventitive mantenence on his 3800 or it could be throwing a code. my question is is the egr making it throw a code or just preventitive thing on it?
Anton Steichen
May 3, 2013 11:07 AM
S.O.G.
Sep 12, 2012 06:54 PM
Skeletal Crow
May 20, 2011 06:49 AM
beaner06
Mar 18, 2007 07:19 AM
SSmonte2006
Oct 4, 2006 02:36 PM
