6th Gen ('00-'05): Check engine light on, help!!
![Unhappy](https://montecarloforum.com/forum/images/icons/icon9.gif)
i know its a long shot, but i need help because i tried to solve the problem but i couldnt fix the car. the check engine light is still on, what are the usual causes for these cars?
taking it in the shop would cost me like 130+ just for the scan!! HELP a BROTHA out!!
Without the code, no way to tell you what's causing it. Most autoparts stores will scan your codes for free.
Or for $15 you could by a very basic ODB-II scan tool to check the code yourself (see the link below):
so i found a place to find the code, and well my 02 sensor is busted in the rear, gotta replace that...and the radiator is leaking some coolant! total damage is like 600-700 bucks -_____- so im stumped.
hotrodharley
11-15-2013 11:37 AM
Tatted
10-25-2013 10:45 AM
tlip06
23
07-25-2011 10:58 AM
tatbone
03-10-2011 09:09 PM
