rear o2?
Old Jul 31, 2013 | 02:13 PM
04IntimidatorSS's Avatar
Default rear o2?
So I got my 3" zzp dp installed not to long ago and the shop that installed it stripped the o2 bung so I just put a plug in it because the o2 sensor wouldnt go back in...I have it tuned out so I dont throw any codes but the wire is just hanging there and when I take it to car washes and get the underbody flush it gets the connector wet and the car will sputter for a couple seconds until it dries out...is it safe to just fill up the connector with hot glue so I dont have to worry about it anymore?
Old Jul 31, 2013 | 08:16 PM
Hot glue is probably fine, but it will more then likely come off in a short time. Maybe cut the cord off the old O2 sensor and make it into a "plug"? Or see if you can pull the O2 sensor wire up into the engine compartment and coil it up?
Old Aug 6, 2013 | 11:25 AM
seen03's Avatar
I've cut the plug off (leaving enough wire from the plug to reconnect if I ever want to reconnect it), then put shrink tune over the individual wires, then shrink tune over both, then tuck the wires up between the exhaust heat shield and under-body.
I've never had an issue with either my GP or SS.
MJClemm
Oct 9, 2022 09:13 AM
