6th Gen ('00-'05): Check engine light on, help!!
Old Aug 5, 2013 | 12:29 PM
HIxArsenaL's Avatar
Unhappy Check engine light on, help!!
i know its a long shot, but i need help because i tried to solve the problem but i couldnt fix the car. the check engine light is still on, what are the usual causes for these cars?
taking it in the shop would cost me like 130+ just for the scan!! HELP a BROTHA out!!
Old Aug 5, 2013 | 01:06 PM
Without the code, no way to tell you what's causing it. Most autoparts stores will scan your codes for free.
Or for $15 you could by a very basic ODB-II scan tool to check the code yourself (see the link below):
Amazon.com: Autel MaxiScan MS300 CAN Diagnostic Scan Tool for OBDII Vehicles: Automotive Amazon.com: Autel MaxiScan MS300 CAN Diagnostic Scan Tool for OBDII Vehicles: Automotive
Old Aug 5, 2013 | 01:30 PM
A steady Check Engine Light is usually related to emissions.
But definitely find out what code is being thrown.
Old Aug 5, 2013 | 03:13 PM
HIxArsenaL's Avatar
so i found a place to find the code, and well my 02 sensor is busted in the rear, gotta replace that...and the radiator is leaking some coolant! total damage is like 600-700 bucks -_____- so im stumped.
hotrodharley
Nov 15, 2013 11:37 AM
Tatted
Oct 25, 2013 10:45 AM
tlip06
23
Jul 25, 2011 10:58 AM
tatbone
Mar 10, 2011 09:09 PM
03SS
Mar 18, 2008 08:31 PM
